OMC 4.3L starting issues
samuelacey
Went to put my boat in the water this past weekend and it wouldn't start. Acted like it had no spark. Got it home pulled the cap to check the points. They looked good, put the cap back on i tried to start and it fired back up. Any ideas on things i should check to prevent this from happening again.
If any moisture found it's way into dist. cap it won't start. And points are cheap, change em out with a new rotor.
