Hello all. Still trying to get this TBI engine to run @ WOT. A previous owner removed the OE Vapor Separator Tank, substituting an aftermarket electric fuel pump incapable of the fuel delivery required to run to WOT. Top speed is supposed to be 43mph. and the engine starts missing and running hot @ 34. To date I've:
Downloaded the correct Mercruiser Service Manual
Changed fuel filter
Cleaned fuel tank and replaced fuel
Checked MEFI-1 ECU for codes: None
Confirmed mechanical lift pump pressure (6 psi)
Installed an high-pressure electric fuel pump that can meet fuel delivery spec
Confirmed electronic ignition is operating to spec
Confirmed all sensors are operating to spec
Confirmed fuel pressure at TBI is correct (30 PSI constant)
Moved fuel return to a portable fuel tank to rule out a restriction on that fuel line
Called multiple Mercruiser shops who have never even heard of, much less worked on this engine
Pretty sure it's fuel starvation. Thinking about taking the mechanical pump out of the system, and moving the high-pressure electric pump to a "push" position close to the fuel tank. Right now, it's mounted on top of the engine, close to the throttle body. It has to suck the fuel through the fuel filter, which may be part of the problem, and its current location is very hot, which may be another part.
Pls don't tell me to "throw a carburetor on it." That's not an easy swap, requiring a whole new ignition system as well. Nobody makes a kit, and I don't have the expertise to build one. If you're not here to help, please don't waste our time. Thank you.
PW
Changed fuel filter
PW
