Results 1 to 8 of 8
    Default 1980 7.5 head gasket
    What is the diference between the Sierra head gasket and the OMC head gasket other than the price? Is OMC worth the extra 10.00? I bought as old locked up 1980 7.5 Johnson motor and got it free and it seems to run good with 95# and 92# compression but I used the old gasket just to check it and now that all "seems" ok would like to put a new head gasket in. Thanks for any info! Jim
    Apr 2010
    4,515
    Default Re: 1980 7.5 head gasket
    I'd go with the cheaper one.
    Feb 2001
    Central West Florida
    15,309
    Yep... What Boobie said.
    We occasionally have questions. If you fail to answer, it may affect ours.
    Thanks guys. With the fact it was locked up I understand. Should I use a gasket sealer or just surface the head? From what I know sealer usually isnt called for on a head gasket? Thanks
    Feb 2001
    15,309
    If the gasket has a glossy look to it, it no doubt already includes a seal material that seals with heat.
    If a plain gasket, just coat it with oil.
  6. #6
    Sounds good. Thank you, Jim
  7. #7
    Apr 2010
    4,515
    On a plain gasket I always used OMC gasket sealing compound. Or Permatex # 3.
  8. #8
    I see the pistons are stamped 030 on this motor. Nothing on it looks like it had ever been apart. Is it possible that it came this way from the factory? Doesnt seem right but if it has been apart they did a fine job of painting it including the black sealer sprayed on the ground wires. I should have the head gasket and waterpump tomorrow so will hope for the best with it. Head bolt torque looks to be 144 to 168 inch pounds correct? Thanks, Jim
  1. 1976 Evinrude 15 hp Head Gasket / Water Jacket Gasket replacement
    By Pandora1 in forum Johnson Evinrude Outboard Forum
    Last Post: 09-10-2018, 11:11 AM
  2. Replies: 3
    Last Post: 06-04-2018, 11:56 PM
  3. 1980 70hp 3yl Johnson outboard/head gasket/water jacket gasket
    By toss42 in forum Johnson Evinrude Outboard Forum
    Last Post: 06-23-2010, 10:13 PM
  4. 1957 3HP Johnson Head Gasket amp Exhaust Plate Gasket
    By tranquilitybase in forum Johnson Evinrude Outboard Archive
    Last Post: 06-02-2009, 12:13 PM
  5. 1995 70HP Evinrude Head Gasket Sealant amp Lower Crankshaft Gasket Seal
    By Clint Osteen in forum Johnson Evinrude Outboard Archive
    Last Post: 02-21-2008, 06:24 PM
