Thefiswhfeeder
Hey all. Newbie here. Hoping to get some help with a 1998 force 40hp. My problem is it was leaking fuel from around the carburetor. I was told before I bought it that it had a new needle valve put in. But it was leaking fuel from around the carb just sitting in the driveway. I've been told three different things. One is it needs a kit. The other is that you can squeeze the bulb to hard and cause it to leak. The other is if the tank, red plastic type which is brand new and new line and bulb, isn't venting it can cause back pressure and cause a leak around the carb. Is there any reason for a leak coming from around the carb?
