Hello, I have 1999 115hp Johnson. The lower unit was replaced before I purchased it. On initial inspection the shift needed adjustment, however cable adjustment would no correct it. The lower unit would need to be removed and the shift rod height needed to be checked. When I checked the shift rod height I found the rod could not be adjusted to factory specs. Has any one encountered shift rod length problems? the O.A.L of the rod is 31"
