Results 1 to 4 of 4
  1. #1
    Default How to check overheat alarm? 65Hp Johnson J0019819 No Tell Tale
    New to the forum and glad to be here. Problem: No tell tale. Afraid of over heating. How do I check the alarm to make sure it works and prevent overheat??
  2. #2
    Join Date
    Sep 2010
    Posts
    19,171
    Default Re: How to check overheat alarm? 65Hp Johnson J0019819 No Tell Tale
    If you do not know the age or condition of the impeller you should install a new one.------But find the tan wire at the cylinder head.-----Slide the rubber boot back.-----Turn key to " on " position.----Touch connecter to the block.----Horn should sound.
  3. #3
    Very much appreciated!!!!!!
  4. #4
    Well explained. Thanks for sharing.
Similar Threads
  1. 1988 Johnson 60 HP overheat alarm
    By bmartsjohnson in forum Johnson Evinrude Outboard Forum
    Last Post: 07-08-2019, 05:21 PM
  2. 1990 Johnson 60 hp overheat alarm
    By Jfdjeep in forum Johnson Evinrude Outboard Forum
    Last Post: 09-12-2016, 12:36 PM
  3. 83 Johnson 90hp- Does it have overheat alarm?
    By DaleSmith in forum Johnson Evinrude Outboard Forum
    Last Post: 09-05-2016, 07:48 PM
  4. Johnson overheat alarm
    By N Wright in forum Johnson Evinrude Outboard Archive
    Last Post: 06-09-2008, 11:35 PM
  5. Johnson 150 False Overheat Alarm
    By brent in forum Outboard motors archive 2000-2004
    Last Post: 07-12-2002, 04:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
