Results 1 to 3 of 3
    Question Chaparral 162 XL Under Splashwell Modification
    I asked this else where without any guidance. I hope at the very least someone can help me understand what this part of the boat is called so I can do more research on my own.
    Per the image attached things are a bit cramped up in the back of my chaparral 162 xl. What I am looking for advice on is if there is a potential issue cutting the fiberglass to the left and right of the current bilge/stow away area (Red boxed in second image.. It sounds hollow, putting an endoscope in there resulted in not much info other than looking like bare fiberglass in there. I really want to separate the gas tank to the Starboard and the electrical to the port while leaving the splashwell/scupper open to drain to the bilge.
    I am totally fine with bare transom in the rear with a hanging splashwell. I don't put anything of weight on there except tools when working. Is there a potential to lose stability on the water from such a modificataion? Has anyone tried something like this before because I was unable to find what I was even asking after a search. Ultimately I am worried about affecting the strength of the transom by moving these hollow fiberglass walls.
    ​​​​​​​https://i.imgur.com/AfG9fo6.jpg
    https://i.imgur.com/PsUNSM5.jpg
    1983 Johnson 90hp V4 on a Chaparral 162XL
    Dec 2006
    Chaumont Bay, N.y., USA
    5,768
    Default Re: Chaparral 162 XL Under Splashwell Modification
    Ayuh,..... Those areas are Usually filled with flotation foam,.....
    Ayuh is the name of the part of the boat? Also sticking the endo scope in there I didn't find any at all. I'm tempted to just break out the reciprocating saw and cut a bigger square to find out. Thank you for replying!
  1. Need advice on splashwell steering tube mounts
    By TheBrain in forum Boat Steering and Engine Controls
    Last Post: 04-05-2017, 03:25 AM
  2. New guages for 98 chaparral 27
    By dmar in forum Mercruiser Sterndrive Forum
    Last Post: 02-20-2015, 10:45 PM
  3. 27' 98 chaparral voltage issue 350 magnum..HELP
    Last Post: 07-14-2014, 07:45 PM
  4. New Chaparral 235 with Volvo 50 GXI wont plane
    By iki in forum Volvo Penta Gas Archive
    Last Post: 08-06-2009, 02:13 AM
  5. 1991 Chaparral 1900 sl yamaha io
    By ohio_boater in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 06-16-2009, 11:42 AM
