Yamaha 70 2 stroke bleed oil injection
Rossy29
Took carbs off today when i pulled the little actuator arm off the oil injection module it pulled the bottom feed oil hose from oil tank. Do i need to bleed the oil injection system now? Thanks
Cheers mate any idea how long that would take? Can i do it on the trailer or would i need to mix a tank up and do it on water?
You can do it on the trailer. Should take about 5 minutes. The longer the better. Use a small plastic gas can to mix your gas and oil.
