I pulled the lower leg to check the impeller. All good.
Put it back together, now i have a solid tell tale.
But noticed a few other water outlets around the lower leg coming out.
Have a looks at the attached pics, is this normal?
There is a small hole at the joint between the top/bottom connecting points where water is coming through.
also from the small holes in the upper part of the lower leg, centrally.
Just never noticed this before, and want to ensure i did not miss something resembling it.
