The engine is in a boat I just got and it won’t spray fuel out of the throttle body injectors.. it’s only sprayed right maybe 2 times but only for about 5 seconds. it runs great if you manually feed it gas.
heres what’s been done and checked:
-i have good pressure in the rail going to the throttle body from the electric pump (50-60psi)
-it had a new distributor, plugs and wires on when I got it.
-noid light showed injectors pulsing and both red wires have good voltage going to them.
- rebuilt the fuel pressure regulator
- new injectors
i just cant figure out why I’m not getting them to spray fuel?? Could the ECM or some sensor be going bad?
any help would be appreciated ����
- new injectors
