Results 1 to 3 of 3
    Default 1978 Johnson 15HP Pull Start Pinion Issue
    Hello all, 1st time posting thank you in advance for any helpful info. I've got a Johnson 15HP model #15R79E, I've had issues with the rewind starter for years now. I've gone thru at least 4 or 5 pinions, they engage with the fly wheel, then after however long they will pop up off the starter pulley and sit sideways, stuck at an angle on the flywheel, I have to monkey with it to get it back in the starting position, but after that the inside of the pinion grooves are no good and it will continue to happen, this last one only lasted about 20 pulls. I'm just wondering what the underlining issue is, any help is much appreciated, trying to get out on the water this weekend!
    -Dustin
    Feb 2001
    Central West Florida
    15,128
    Default Re: 1978 Johnson 15HP Pull Start Pinion Issue
    There's a washer (part #318937) between the bendix gear and the underside of the retaining screw. With that washer in place, it is impossible for that gear to rise any further than the underside of that retaining screw.
    Available this site $9.50
    We occasionally have questions. If you fail to answer, it may affect ours.
    Ah yes I see, I am definitely missing that washer. That should do it, much appreciated!!
  1. 2007 Johnson 15hp pull start vs 1989 Evinrude Elec/ and pull start.
    By ChanceG in forum Johnson Evinrude Outboard Forum
    Last Post: 10-09-2017, 07:26 PM
  2. convert 86 15hp pull start to electric?
    By Jason Dickey in forum Johnson Evinrude Outboard Forum
    Last Post: 07-13-2014, 06:56 AM
  3. Evinrude 15hp tiller handle pull start
    By srichoux in forum Johnson Evinrude Outboard Archive
    Last Post: 04-29-2008, 08:54 PM
  4. 1986 Johnson 15hp Pull Start Assembly Problem
    By sgruebs870 in forum Johnson Evinrude Outboard Archive
    Last Post: 10-24-2007, 07:58 PM
  5. b88 15hp johnson pull No cold start
    By davenash in forum Johnson Evinrude Outboard Archive
    Last Post: 07-16-2007, 12:41 AM
