MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 5 of 5
    Default Mariner 200 Upper Shift Shaft
    Hello Guys
    I have a bent upper shift shaft in my engine making a bit hard to shift between Neu-FWD and Neu- rev . The shaft make some contact with the inner walls or sometimes not engage the shift properly.
    How hard is to replace this shaft? Do I have to take the powerhead off in order to replace it?
    SN OT149104
    Modee 2000 200CXL SW
    Nov 2011
    tennessee
    3,473
    Default Re: Mariner 200 Upper Shift Shaft
    I have heard of people doing it but I tried and could get shift rod high enough to knock out roll pin.
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
    Sep 2003
    New Tripoli, PA, USA!
    16,078
    Good luck with that! The PH has to come off. Sorry.
    Jeff
    So you mean it is possible but you personally tried it unsuccesfully?
    Nov 2011
    tennessee
    3,473
    Ya......but twas a 150
  1. Shift shaft upper
    By Mariah in forum Mercruiser Sterndrive Forum
    Last Post: 08-04-2018, 11:38 AM
  2. Upper shift shaft removal on a 1964 Mercury 850
    By tlcausey in forum Mercury Mariner Outboard Forum
    Last Post: 02-20-2018, 06:47 AM
  3. 1968 Mercruiser 120 oil leak @ upper shift shaft
    By Fisch in forum Mercruiser Sterndrive Forum
    Last Post: 09-12-2010, 06:38 AM
  4. Bravo3 Failure of Upper drive Shaft and Shift Collar
    By outriggers in forum Mercruiser Sterndrive Forum
    Last Post: 05-08-2010, 07:22 AM
  5. 1985 Alpha leaking lube from upper shift shaft
    By shawn in forum Archive 2003-2009
    Last Post: 05-16-2003, 05:13 AM
