I have a 2000 Honda 130 engine that’s been giving me surge issues with the rpm. A spike an dip in power. Today the engine would go only as far as 4000 for a moment than kick in and go up in RPM. Yesterday I ran for 24 miles without an issue. The day before I was running at 4400 an had a loss of power to 3000. I could not go pass 3000 for a moment and then it kicked in. This issue has only occurred in last few weeks. Both my 130s were serviced a year ago. Since then I have replaced the racor a month ago. Should I go ahead and change other fuel filters? Could it be the spark plugs? They were changed a year ago to.[/QUOTE
First up, you are very brave running 24 miles out with a motor that's playing up. I would probably start with a fresh set of spark plugs although I am tending toward a cylinder dropping out and back in, ie possible spark issue ( usually a spark plug fails and that's it) . The drop in RPM you mention tells me you're probably only dropping one cylinder. When you remove the spark plugs, carefully inspect the plug caps that go down the tubes for hair line cracks and carbon tracking. If neither works you are going to have to find an assistant and when you have a drop in rpm, hopefully in flat calm water, pull the plug leads out one at a time using plastic pliers made specifically for that job so you don't get a violent jolt, and try and identify the offending cylinder. I have known the ignition coils to fail on one lead. Sorry, there's no easy way with these older motors. Start with those suggestions in the order I have put to you and see what you come up with.
