brettmarl
Crap... I think I just realized I used the wrong gear oil in my lower units.
I put this stuff in:
Mercury SAE 80W-90
https://onlineoutboards.com/products/mercury-gear-lube-sae-80w-90
I meant to buy the Mercury High-Performance SAE 90.
As I'm cleaning up my shop - just noticed on the bottle of the 80W-90 it says "For use in all outboard lower units and jet pumps below 75 hp except outboards with electric shift gears".
I've probably only done 1-2 hours on the motors with this in. Obviously I should pull the boat and replace, but then I just read this:
"NOTE: Mercury Premium SAE 80W90 Gear Lube should not be mixed with Mercury High-Performance SAE 90 Gear Lube."
Couple of questions:
1. any possibility I did damage for the short runtime?
2. Does the "do not mix warning" mean - don't use a blend of both? If I empty, fill with SAE-90, dump it all to flush and fill again, am I in the clear or is trace-stuff mixed a bad thing?
I self-nominate for the dumb-ass of the week award.
Mercury SAE 80W-90
