I believe all of my vessel's weight rests on the rear axle. there is a 1/2" gap at front of bunks. this unloaded front leaf spring suspension created a huge vibration of the front part of I-beams frame I'm convinced this is what caused the brace to crack and break.
doe's the aft. need to be elevated to lower the front so the hull rests properly dispearsioning the weight to both front and rear axel? vessel appears to be tilted front up like the front seams a tad high.
or can the front of bunks be elevated to rest up against hull like would this load the suspension?
the cross brave is a hardwareless type size 3"x3"x78" having a difficult time finding a replacement, that's if I choose to replace over welding. when I google hardwareless the google thinks hardware and that's basically a messed up search.
I'm still waiting unoptimistically for a response from sunshine of tallahassee they are the manufacturer..
this trailer was purchased 2 years ago and I've never paid any attention to the unloaded front suspension, this trailer had been rear ended same exact top of cross brace which I had welded and reinforced.
edit: this pass. side constantly bouncing tire front has abnormal wear (cupping). I need this taken care of soon because red snapper season starts june1.
Thanks for advice.TB
