Results 1 to 6 of 6
  1. #1
    Question Busted engine block
    I bought a 2002 Bryant with a frozen & busted 350 engine block. The heads and manifolds look okay. It only has 380 hours on it. I have a good Vortec engine block from a van. Can I put brass freeze plugs in it & use this block?
  2. #2
    Join Date
    Mar 2019
    Location
    Ottawa Canada
    Posts
    532
    Default Re: Busted engine block
    I would have the heads and the manifold checked also. As for using a truck engine. It probably won't last long. Unless it's rebuilt. Racing around at 5000 rpm with blow up that engine quickly.
  3. #3
    I just want to use the block. I will use the internals, cam, crank, pistons, etc. form the boat. Just wanted advice on weather the engine blocks are the same. I'll get a rebuild kit for bearings and gaskets. I have been a mechanic forever, just don't know a lot about boats.
    Are the freeze plugs the only thing I need to be concerned with?
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    6,015
    Ayuh,..... The blocks are the same,..... core plugs, 'n head gaskets are different,.....
    I wouldn't trust the heads either,.....
  5. #5
    I will have the manifolds and heads checked. Thank you all for responding.
  6. #6
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    11,996
    Brian, if the cylinder block (same year/model) will accept your crankshaft, camshaft, roller cam followers, etc, all should be OK.
    As for the casting core plugs (aka welch plugs), brass would be best, although if this will soon be fitted with a closed cooling system, the brass welch plugs may not be necessary. I would go with brass..... the cost difference is minimal.
    Likewise with the head gaskets...... Marine if raw water cooled, high grade automotive if soon to be fitted with a closed cooling system.
    I agree, have the cylinder heads and intake manifold magnafluxed.
    When you reach the point of adjusting cam followers, use the tried and proven 8 stop static procedure..... not the 2 or 3 stop!
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP drives
    "Intellectual growth should commence at birth and cease only at death." Albert Einstein
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. BUSTED manifolds
    By seasport4.3 in forum Volvo Penta Gas Engine Forum
    Last Post: 01-25-2019, 05:10 PM
  2. busted starter bolt in the block chevy 350 volvo penta 290
    By vegas in forum Volvo Penta Gas Engine Forum
    Last Post: 09-08-2018, 01:07 PM
  3. 305 Mercruiser froze and busted block this winter
    By ctrot20 in forum Mercruiser Sterndrive Forum
    Last Post: 05-08-2014, 08:52 AM
  4. Water in engine oil after busted clamp
    By sheehyjo in forum Mercruiser Sterndrive Forum
    Last Post: 08-03-2012, 12:08 AM
  5. Oil hose busted
    By kevin_z in forum Crusader Marine Archive
    Last Post: 09-10-2008, 03:57 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
