anyone ever do prop seals on a dp'sm v/p drive?
stang32
the drive is leaking oil from the props, inspection found fishing line wrapped around the prop shaft and oil leaking out of it,
can the seals in the shafts be replaced without special tools, or should i say, what tools are needed to do this job?
I looked into doing this myself as well. The props need a special tool, which is easy to fabricate from a pipe, but the problem comes from the thrust ring. I havent found a way to fabricate one for that.
thrust ring # 3851327 (old one is re-usable)
Spanner tool # 3855877
Spline Socket # 3850598
