I'm breaking out my 97 starcraft 1710 with a mercruiser LX alpha one stern drive. I jumped the boat and the motor spun. Which is good news.
Yes, good news.
It was stored with fuel in it quite possibly with ethanol . What do I need to do to deal with the old fuel sitting in the fuel system for 9 years?
E-10 or no E-10, I would remove and dispose of 9 year old gasoline. The lighter molecules have evaporated and the octane rating has diminished by now. It's not worth trying to save and use given the problems that it may cause.
Should I pull the carb and clean it?
Not a bad idea!
I would also replace the anti-siphon valve, the primary fuel filter cartridge and the carburetor filter (if equipped).
Obviously pump out the old fuel.
Yes!
Do I need to pull the fuel tank and clean or replace it?
Since this is a smaller trailer-able boat, you can take the boat for a mild bumpy ride as to shake things up.
After draining and disposing of the old fuel, you can add perhaps 5 gallons of Non-Ethanol fuel.
The fuel tank will be fitted with a dip tube. The dip tube may be equipped with a screen at the bottom.
If you can pull this out of the tank, you can examine the screen and clean it if need be.
Besides changing motor oil and filter, lower unit oil what else would need to be done As standard maintenance?
First examine the engine oil and stern drive gear oil. If it is clean and still fresh looking, it should be OK to run it.
If dirty, then yes...... change it!
If you do perform a stern drive pressure/vacuum leak-down test, the oil needs to be drained for the pressure leak-down test.
If the boat had been stored for 9 years with the stern drive UP and/or turned sideways, you will definitely want to replace the drive shaft bellows.
After having been at rest within the pump body for 9 years, the seawater pump impeller has no doubt taken a "set" and needs to be replaced.
