2001 80hp
I replaced head gasket but still getting water in oil.
I ran the the engine after head gasket replacement for about 2 hours. Checked dip stick and oil looked good, no milkyness. Pulled oil drain plug and about 2-3 tablespoons of clear water came out before any oil. So i figure I'll replace all the gaskets and seals that may be allowing water in.
Question is which seals and gaskets should i replace?
In my manual it shows the gasket that separates the powerhead from mid section and a gasket between the mid section and oil pan. Any other gaskets and seals?
