Is this a salt water boat? Or was it?
Try a more vigorous penetrating fluid. You may have to use a little heat. I would suggest a propane torch as an oxy acetylene torch is way to hot. Use a block of hardwood and a heavy hammer. And pound away. A gòod indication when using the heat would see the penetrating fluid start to boil. Then hit it.
That worked. Pin removed. Thank you for you help and guidance.Just be careful
Ive seen the trim cylinders used before to pop the drive loose before, small bumps.That worked. Pin removed. Thank you for you help and guidance.
Now im trying to remove the lower unit with the drive shaft. 6 nut’s removed, shift cable removed, and both hose clamps to both bellows to transom removed. Used heat and knocker loose penetrant on the 2 studs that shown corrosion. Supported the housing level and tried to pull it out. No separation at all. I even tried to wrap a rope around the lower part of the housing, then to the eye bolt at the dipstick hole, then down to a brass rod I stuck through where the pin was, and back up to the eyelet where I tied the rope in the center of the pin and eyelet. I pulled with all my 320lb 6’4 body had to offer. Many times, and no movement what so ever. Any suggestions or tips would be great!
i used a high temp heat gun. Also spraying it many times with penetrant while it’s hot. I removed the other end that you’re taking about. My hammer is a 32oz ball peen, and a 1/2” brass rod about 18” long. It took a lot of hits to move it a little. Then I went to the other side, and sprayed it again, heated it again, and hit again, and again. With a smaller diameter shaft that fit through the housing I was able to drive it completely through without heating it anymore. I noticed one side was corroded a little but the other side wasn’t. I did the final push towards the corroded side.I also am battling the trim cylinder pivot pin at the gimbal ring end being stuck, did you use the propane torch? were you trim hoses removed?
TIA
