I've owned this boat for 2 plus years, twin Johnson's 175 HP (J175PXSTM) 25 inch shafts. This motor has always seemed to run richer then the port motor with excess oil around the carburetor/intake side of the powerhead. This motor stalled out periodically, but always cleared up until the last 2 or 3 trips. Stalls out going into gear if 800 RPM or less. The last compression test were equal for all cylinders. I ran this motor twice today 10 minutes each time. The oil light and alarm sounded within the first 10 seconds, then went off. I shut it down and restarted without an oil issue again. (boat on the trailer) While I was cleaning the carburetor side of motor, I notice an upper carburetor mounting bolt missing from a center carburetor. I replaced the bolt, but have not run the boat in the water. I don't know if this fixed my problem, will run in water under power as soon as possible. Your thoughts and thank you for your help.
