am_dew
Advanced Contributor
The water pump on an AQ130C has a very thin gasket between the pump cover and the pump body that needs replacing every time you replace the impeller or remove the cover. The pump cover is the secured to the pump body by 8 small screws. As my finger and hands get less nimble as I get older, I am finding it very difficult to secure the cover while making sure the gasket is in it's proper position. What can I use to hold the gasket against the cover or pump body before I install the cover? Or is there a better method? What are those thin gaskets made out of?
