i just finished this and I am getting a lot of water coming out the area where the shift arm comes out of the lower unit and nothing out of the top end. i took it back apart and put the muffs on the lower unit. there is a lot of water escaping from the top of the waterpump housing, where the driveshaft runs through it. there is flow through the water outlet on top of the pump housing as well. it looks like there should be some sort of seal on top of the pump housing, like the alpha units. but the housing is all hard plastic. there is a gap between the impeller cup and the top of the housing but nothing goes there, i looked at the parts breakout andit doesnt show anything.
i sent compressed air up through the water intake tube of the upper unit and i hear air coming through the combustion chamber but there seems to be alot of back pressure when i let go of the trigger. this is a river boat.
