Click for Detroit Diesel manuals!
Results 1 to 4 of 4
  1. #1
    Default Droplets of Coolant in 6V92Turbo Pan
    So in the course of re-establishing oil pressure to my 6V92T (oil filter), I discovered a small amount of coolant in the bottom of the pan.
    I am wondering the most likely sources for the contamination?
    Brett
  2. #2
    Join Date
    Nov 2009
    Location
    temecula, ca., usa
    Posts
    3,297
    Default Re: Droplets of Coolant in 6V92Turbo Pan
    It sounds like you have a closed, pressurized cooling system. Is that correct?
    What air cooling does it have? Intercooler? Aftercooler? Both?
    One thing about a pressurized system is that a small leak can spray and be seen in an area, away from the source, that might not seem logical.
    Another thing about ANY liquid leak is that gravity will pull it far from where it originated and have you fooled sometimes. Always look UP, when trying to find a leak,
    to the highest place that particular fluid could possibly come from.
    I have never seen a liquid cooled turbo on a 92 but that doesn't mean they don't exist. If you are running one of those, the coolant lines and fittings are definitely where to examine closely first.
  3. #3
    Yes, closed pressurized. After cooled. Also has an oil cooler.
  4. #4
    Join Date
    May 2015
    Location
    Oregon
    Posts
    131
    If you can't find a source for the coolant, try putting some toilet paper around the hose connections, cooler, etc. or use something like powder anywhere coolant flows. Sometimes even a quality hose will develop a pin hole leak. Often only seen when the system is up to pressure.
Similar Threads
  1. 6v92Turbo not building oil pressure
    By MakingMemories in forum Detroit Diesel
    Last Post: 04-23-2019, 06:33 AM
  2. AQAD40B coolant leaking through coolant filler cap
    By Yobbo in forum Volvo Penta Diesel
    Last Post: 08-31-2017, 07:34 PM
  3. Oil in coolant
    By norton in forum Mercruiser Sterndrive Archive
    Last Post: 06-29-2009, 09:42 PM
  4. 84 MC 470 Low on coolant
    By a1nowell in forum Mercruiser Sterndrive Archive
    Last Post: 05-05-2009, 09:53 AM
  5. Coolant for 350 XL
    By mike_jb in forum Crusader Marine Archive
    Last Post: 06-10-2008, 11:50 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
