115hp 4stroke high throttle limp mode.
kracer58
Motor will run great at high throttle for a little bit then go to limp mode. It will start beeping. I can shut the motor off and restart and it will run great as long as I don't go to full throttle again. Any ideas? Thanks
Alarm is going off. Telling you to check the motor. The ecm is limiting the rpm It's either overheating or you have no oil pressure..
