N2 Fishing
So I have this annoying over heat alarm that have been going off at idle and lower sub 2200 rpm range while in gear. New water pump installed, Thermostats checked out ok over the stove in a pot of water and both are fully open by 135F.
I installed a Suzuki 35 psi water pressure gauge and get practically no water pressure at idle and the gauge does not start to move until about 1150-1200 rpm. I get 15psi or more at about 3000 rpm.
I pulled the thermostats out and lower unit off to test for flow from the thermostat housings in the video below. I get good water flow when I turn the water pressure up from the garden hose spigot. If I don't turn the water pressure up to almost full blast I only get water flowing through one thermostat housing. I think this is because the water exiting the thermostat housing is about equal to the amount of water going into the lower pick up tube.
I also recently installed a different monitor gauge because the original was left outside for a few years and weather took it's toll so some of the lights were no longer working.
I have had this issue since about 2006 when I purchased the boat this engine is on.
I checked the Port side heat sensor and I get Ohms readings but on the starboard side I get no Ohms readings at any temperature. Is this normal?
https://www.youtube.com/watch?v=eDIwiGwJKvI
