Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 8 of 8
    Default Locking Ring Wrench FT-11275
    Does anyone know where I can purchase a locking ring wrench, Force/Mercury Part FT-11275? Mercury no longer carries it, as do the major suppliers. I came up negative on Amazon and EBay also. I was told I can make one out of a piece of pipe. This may be my only alternative. This tool is used to remove the large ring holding in the bearing carrier in the lower end of a 1993 Force 90 hp. Any help would be appreciated. Thanks.
    May 2010
    Sebastian ,Fl
    2,783
    Default Re: Locking Ring Wrench FT-11275
    If you have the ability, make it.
    The other way is you can cut it out and replace it??
    Don't use a torch to get it out, gets too hot and melts the housing.
    Use heat and penetrating oil before you try to remove it.
    Post a pic of the tool you make.
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    88 Bayliner with 2002 225 HP Mercury
    Buy American made Cars and Trucks!!!Towing insurance,get it.
    In Scenic Beautiful Sebastian by the sea Florida
    Thanks Jerry. Getting shakey about trying this myself. May just drag it off to a Mercury dealer to see what they can do. Appreciate the advice. Will let you know what I decide.
    Mar 2019
    Ottawa Canada
    454
    You can drill it out if you are careful. Don't hit the threads in the case. Drill 2 holes an inch apart if you get enough meat off the ring you can pry out the inch piece. Then the rest you can pry out. Just be careful of the threads.
    May 2010
    Sebastian ,Fl
    2,783
    The locking ring is soft pot metal.
    I use a hacksaw blade and make the 2 cuts and then pry it out.
    The threads are soft too(aluminum) and easy to clear out.
    If you decide to make a wrench??
    Make 2 and send me one
  6. #6
    Going to see an old time mechanic tomorrow who works on older stuff. I am willing to farm the job out than to screw it up. I know my limitations. They should have the tool. I will let you know how I make out. Thanks for the suggestions.
  7. #7
    May 2010
    Sebastian ,Fl
    2,783
    I've done the cut and pry a few times.
    That wrench doesn't always get the retainer out
    If you do try? remember to bend the tabs back on the lock ring.
  8. #8
    Found an old time mechanic who was willing to take the job on. Big load off my mind. Just did not feel comfortable tackling this job. Thanks for all the advice.
  1. Replies: 12
    Last Post: 07-17-2017, 04:45 PM
  2. 84 115 evinrude piston ring install.. which way does the 1 ring go?
    By comet424 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-12-2015, 09:27 AM
  3. 90185-10m14-00 nut, self-locking --- nut, self-locking
    By bloaky in forum Yamaha Outboard Forum
    Last Post: 06-18-2013, 07:47 PM
  4. Oil filter wrench
    By sugar_mama in forum Yamaha Outboard Archive
    Last Post: 05-04-2009, 04:03 AM
  5. Clamping Ring O ring repl
    By jon_allen in forum Volvo Penta Gas Archive
    Last Post: 07-18-2008, 03:50 PM
