Click for Nissan Tohatsu Manuals, and Parts!
Results 1 to 2 of 2
    Default Proper tank and vent procedures?
    I have a 2006 Tohatsu 6hp four stroke. I bought a Tohatsu tank and hose 18 months ago. I had to replace the engine side hose connector when the O-ring was damaged a month ago. All I had access to was an aftermarket connector. The tank side is the “coax” type.
    If I disconnect the hose from the engine during a sunny day I see fuel leaking out of the engine side hose connector. If I release the cap to release pressure, later in the evening the tank collapses from the negative pressure as the fuel cools.
    Should the cap vent be closed during the day when the engine is between uses?
    when should I disconnect the engine side connector?
    when to disconnect the engine side?
    Any other tank and hose considerations?
    thanks,
    harry
    Mar 2010
    Hamburg, NY, USA
    2,463
    Default Re: Proper tank and vent procedures?
    The engine-side connector should not drip. If it does, the internal valve is either damaged or just not seating. What end did you buy? The corrct part is:
    FUEL CONNECTOR - ENGINE/FEMALE (4-STROKE)
    DescriptionFemale fuel connector - Engine side 8mm (5/16")
    This is the connector that is installed on the fuel hose that connects to the motor.
    Fits all 4-stroke models.
    Part #: 3GR702500M
    List Price (MSRP): $22.45
    As for the tank, it seems you have an EPA-rated tank. That can pressurize to 5 psi in the sunlight, and develop a slight vacuum when it cools. These have a check valve in the vent. Personally, I prefer the older kind with a real vent.
    The engine-side connector should come off at the end of every day, so that you can run the motor until it stalls, using up the fuel in the carb. This gets critical when you let the motor sit for a week or two. If full of gas, it will varnish up.
    Paul
    Certified Tohatsu TLDI Technician
    Hamburg, NY USA
  1. forgot to vent tank
    By Toddstir in forum Mercury Mariner Outboard Forum
    Last Post: 06-10-2018, 08:20 PM
  2. Gas Tank Vent
    By oakcenter in forum Boat Fuel Systems (separate from engine)
    Last Post: 09-12-2015, 06:57 PM
  3. Chrysler Tote Tank Cap Vent
    By Redhawk4 in forum Chrysler Force Outboard Forum
    Last Post: 08-28-2012, 10:56 PM
  4. Should I cap off the vent for the gas tank during winter
    By lbisurfcaster in forum Johnson Evinrude Outboard Archive
    Last Post: 12-11-2008, 02:05 AM
  5. Question about vent screw on tank
    By Mark Ohio in forum Outboard motors archive 2000-2004
    Last Post: 10-23-2001, 10:03 AM
