During engine tuning, when I plug in the shunt wire, my 1996 4.3 GS V6 doesn't change in RPM like it use to! Could it be a bad module on the distributor? Bad coil?
So, is the advance curve with the EST similar to the stock distributor with the weights?
So, is the advance curve with the EST similar to the stock distributor with the weights.
Sort answer is No.....jeffnick said:So, is the advance curve with the EST similar to the stock distributor with the weights.
Mine is not OEM. It's on a 260A. It seems like the advance happens quite quickly toward the upper rpm.
