Hello All
I'm Lukas, and this is my first post on this forum. I hope, I will find help here.
I have Mercury ELPT 90HP, 2-storke with BigFoot lower unit. Serial no. 09962873.
Engine is in good condition, but When I bought, engine didn't have reverse gear. I'm trying to repair this, now. I have all new bearing, seals, I reparied reverse gearwheel and clutch.
But, during assembly, I see a problem with axial clearance of the propeller shaft. You can see this on this movie:
https://drive.google.com/file/d/11QFIyKFGTu3WuhDzgmSedfW1EN1Ei2zh/view?usp=drivesdk
When I disassembly lower unit first time, I saw, the thrust bearing has dropped between the housing and the toothed wheel. That's happed because, reverse gearwheel had also too big axial clearances.
This is normally in this lower unit? What I can do to eliminate this slack?
Other problem is, when reverse gear is engaged. Clutch touch teeth on the reverse gearwheel only on the 60%... You can see more on the photos. Something is wrong adjusted? How to do this to have bigger surface of the touched teeth?
Here is a folder with photos on the OneDrive from disassembly, inspection of the parts and grinding gearwheel with clutch:
https://1drv.ms/f/s!AkJqECnhCE-8njs8ca-tq8uPR0m1
Also on the photos is showed, how work reverse gearwheel with clutch inside lower unit (marked by yellow paint).
