MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 9 of 9
    Default 60hp mariner cylinder issue. (Misfire)
    Ok. So I'm ready to pull my hair out. 97 mariner 60. I have been chasing a odd miss. It is not a dead miss but it pops and spits and no power. It's the middle cylinder. All 3 have 130lbs compression. All carbs good. I swapped coils and issue stays on no 2 cyl. I tested spark and it is present as will jump a 7/16 gap with ease. I am out of ideas unless it's the switch box or trigger coil.
    Sep 2010
    ontario
    16,736
    Default Re: 60hp mariner cylinder issue. (Misfire)
    Perhaps inspect for cylinder sleeve out of position ( rotated ) ----Possibly due to overheat.
    Mar 2019
    Ottawa Canada
    440
    It could be your switchbox. I've had engines run perfectly above 2000 rpm. Then at idle 1 cylinder would drop out. The switchbox would be my guess. The trigger rarely. But if your unsure . It's best you get yourself spark testers that you can put between the sparkplug and the boot. Not the adjustable gap kind. These testers show an orangish light when it fires up. Then keep your eyes on the number 2 cylinder . If you suspect the cylinder has rotated as racerone says, it may have overheated. Your welcome to try that also.
    Quote Originally Posted by mechanicman View Post
    I used a non adj spark tester as well. Its solid the whole time. I pulled reed plate off and all looked well. How should I ck for cyl rotation? Would it not effect compression. Thanks. One more thing and I know it's not proper but it will crank on just cyl 1 or just cyl 3. If you try just cyl 2 it pops very bad nut will not start
    Mar 2019
    Ottawa Canada
    440
    I'm sure racerone can answer that question. About cylinder rotation.
    Well maybe you have a carb issue. Can you see inside the carbs when it's running. Check for fuel spray as you rev it up. Should be a mist. Could be that it's dripping or pouring. Does this misfire only happen at certain rpms?
  6. #6
    Carbs are good. It does it at all speeds.
  7. #7
    Sep 2003
    New Tripoli, PA, USA!
    15,861
    I had a customer's 60 that did that. Was a bad reed valve.
    Jeff
  8. #8
    They look well seated. All look the same. It's about to drive me crazy. I keep hoping it's something simple I'm missing. How is best way to check for a rotated sleve
  9. #9
    Nov 2011
    tennessee
    3,338
    Index the flywheel and check timing on each cylinder.
    Pappys Sales and Service
    Owner and Factory Certified Technician
    Former racer KDBA (Kentucky Drag Boat Association)
  1. Tach/rectifier issue on Mariner 60hp
    By Coxn in forum Mercury Mariner Outboard Forum
    Last Post: 09-06-2018, 06:17 PM
  2. Mariner 60hp Drops Cylinder Above 1/2 Throttle
    By StevensPoint in forum Mercury Mariner Outboard Forum
    Last Post: 08-19-2018, 03:18 PM
  3. Mariner 60HP 3 Cylinder Butterfly Cover
    By kalvinrlh in forum Mercury Mariner Outboard Forum
    Last Post: 12-31-2010, 11:55 AM
  4. Mariner 60HP 3 Cylinder Water Pump
    By MarinerScott in forum Mercury Mariner Outboard Forum
    Last Post: 07-31-2010, 09:04 AM
  5. Mariner 60hp 2 cylinder 2 stroke idle problems
    By steve webb in forum Mercury Mariner Outboard Archive
    Last Post: 07-28-2007, 09:16 AM
