Results 1 to 17 of 17
  1. #1
    Default 1973 Slickcraft SS235 225hp 800series 990211F electric shift prop shaft broke and upper leaking
    I just bought this boat for $800.
    Very good condition but the drive and power unit is in rough condition.
    Pulled prop and the end shaft crumbled into pieces.
    The upper is leaking thru the water port. After all that I started it up and sounds like the 307 has a bad rod. But the engine is the least of my worries.ill just replace with a bone yard 350.
    My question is . How hard is it to replace the prop shaft and fix the upper unit? Or should I just go find another avenue to get boat going?
  2. #2
    Join Date
    Sep 2010
    Posts
    17,802
    Default Re: 1973 Slickcraft SS235 225hp 800series 990211F electric shift prop shaft broke and upper leaking
    Perhaps look for another boat.-----Used outdrive for that is available in some areas.----Your location ?
  3. #3
    Northwest Ohio
  4. #4
    Join Date
    Sep 2010
    Posts
    17,802
    OMC sterndrives are not at the top of the popularity list.-----Best to look that up.-----Then look for another boat.-----
  5. #5
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,880
    Ayuh,..... Good luck with that,....
    There's no parts for that drive, nor accessory parts for that motor,......
    Swappin' in a Mercruiser or Volvo is the only way to save the hull,.....
  6. #6
    Thought you couldnt change over due to the huge round hole in transom. How would you go about doing that?
    Join Date
    Sep 2010
    Location
    Jersey Shore
    Posts
    5,701
    Get a different boat.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
  8. #8
    Join Date
    Sep 2010
    Posts
    17,802
    Neighbor had a fine 24 foot' " Thomson built " 1966 Chris Craft.------The OMC V-6 was removed in 1990.-----An expert reworked the transom.-----A Mercruiser 188 V-8 was installed.-----Still working like a charm today after several new owners.----Even the 76 Johnson 15 HP that I rebuilt in 1988 is still on it.------If you need a propshaft for that drive I have some.
  9. #9
    What would be your estimate for total cost of prop shaft replacement? With seals and all.
  10. #10
    Join Date
    Sep 2010
    Posts
    17,802
    With a shop doing the work ( if you can find one ) it would easily take $500/600. + parts.---If salt water motor all bets are off.------Where did you came up with this 800 series thing ?----Any pictures of this drive ?---A new propshaft appears to be less than $200.
  11. #11
    i have try multiple ways to attach a pic with no luck.
  12. #12
    Found a 1969 evinrude sportsman 155 w a Chrysler v6. The stringer is good. Looks the same but will it work? For the hp difference
  13. #13
    Join Date
    Sep 2010
    Posts
    17,802
    A Chrysler V-6 or a Buick V-6 ??
  14. #14
    Crysler I was told
  15. #15
    Join Date
    Dec 2006
    Location
    Posts
    5,880
    Ayuh,.... OMC used Buick V6s, 'n V6 outboards, turned on their face,....
    Never seen a Chrysler with an OMC, 'n I don't think Chrysler was buildin' V6s then,......
    Chevy V6s came later,....
    'n the gear ratio won't work anyways,....
    Ya strip out the hull, glass in the old hole, 'n cut in what you need,.....
    Problem is findin anybody willin' to work on a stringer drive,.....
  16. #16
    Join Date
    Sep 2010
    Posts
    17,802
    They used a V-4 outboard in the early ( 1960's ) OMC 88 / 90 HP sterndrives.-------No such thing as a V-6 outboard at the time
  17. #17
    Ok thanks. Lucky we have an old omc dealer close to us and he's gonna replace whole drive for a decent price.
    Engine update. Was only a stuck valve. Repaired and runs great now.
Similar Threads
  1. Shift shaft upper
    By Mariah in forum Mercruiser Sterndrive Forum
    Last Post: 08-04-2018, 12:38 PM
  2. 1973 Electric Shift Sterndrive
    By Hawger in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-22-2014, 09:03 AM
  3. OMC 1973 outdrive electric shift
    By J D in forum OMC Sterndrive and Inboard Forum
    Last Post: 06-10-2014, 10:59 AM
  4. 1976 Slickcraft SS235 Mercruiser 888 Questions
    By ricardorocha in forum Mercruiser Sterndrive Archive
    Last Post: 09-22-2008, 07:33 PM
  5. 1985 Alpha leaking lube from upper shift shaft
    By shawn in forum Archive 2003-2009
    Last Post: 05-16-2003, 06:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
