Results 1 to 2 of 2
  1. #1
    Join Date
    May 2012
    Location
    Salem MA
    Posts
    10
    Default Changing large outboard - want to treat wood transome and bolt holes Parker
    Changing my 1990 23.5 Parker 200 HP outboard. Concern about integrity of transom and would like to take preventative maintenance measures. Once the engine is removed was thinking treat the bolt holes; maybe some sort of penetrating epoxy. No idea on the brand or type. Also was wondering, if something like this is advisable; how to treat the topside of the holes (fighting gravity) just brush it the best possible or is there some clever way to block the holes and somehow fill it to get maximum saturation? Let's assume the holes/internal wood is now treated and dry; what would be used to seal the holes / bolts; some sort of 3M 5200. I'm not looking to cut corners.
    Regards,
    jj
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,270
    Default Re: Changing large outboard - want to treat wood transome and bolt holes Parker
    A big rubber mallet should give you an indication of the transom's condition.
    The OEMs making penetrating epoxies usually have good directions for using their products. Their tech support people can usually help you with a specific condition - never hurts to ask.
    As far as the bolts holes go, using 5200 as things are assembled is usually adequate to keep the water out.
Similar Threads
  1. Using Valve Cover bolt holes for lifting engine
    By themons in forum Crusader Marine Engine Forum
    Last Post: 05-14-2014, 12:48 PM
  2. Replies: 4
    Last Post: 04-29-2012, 01:29 PM
  3. Need to chamfer bolt holes for volvo transom shield
    By pcmpete in forum Volvo Penta Gas Engine Forum
    Last Post: 05-28-2011, 07:13 PM
  4. Outboard on Large Sailboat
    By maisso in forum Yamaha Outboard Forum
    Last Post: 04-11-2010, 02:23 AM
  5. Changing out aq170 what will bolt up
    By stvdalton in forum Volvo Penta Gas Archive
    Last Post: 04-14-2009, 02:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
