Hi all: I started my Merc last 2 weeks and it ran fine until it cut off and would not restart.
What I did:
I flushed the tank and lines. It is on a 2007 Boston Whaler 150 Sport. with approximately 240 hrs (second owner) ( fairly new good black rubber fuel lines). Installed new filters. High Pressure, Low Pressure, and Water separator filters. I also took off the VST and cleaned it out and replaced the screens. I checked the Low Pressure Pump (fairly new) but it is clean inside. Changed Spark Plugs. It started right up after all that, but it will not run properly between idle rpm to approximately 2000rpm. It idles with a little shake and I can accelerate it to 3500rpm( don't want to rev beyond). It will run at above 2000rpm, but sometimes cut back down to 1000 and back up to 1700, to 2100 and fluctuates as if it was starving for gas.
I ran through some SEAFOAM to further clean things out. Same issue. I was able to do a pressure test on the VST and it is at 42 psi and stays the same whether it idles or is revved up. I have the boat out the water and on ears, so I don't want to run it beyond 3500rpms.
I took off the ICA solenoid and with 12 volts it opened. I also checked the resistance which was 29. However, once or twice when it was running between 1200 to 1700 rpm (fluctuating up/down) I blocked the upper opening of the IAC and it seemed to level off. (this valve makes the PAKA PAKA sound as others described. It just want to bypass the 1000 to 2000 rpm. I took off most of those plastic ties and replaced with stainless steel clamps just to see if it was leaking etc. I would have taken it to the dealer, but was hospitalized recently from a heart attack and had an intervention surgery. The bills are currently horrendous. I want to thank anyone who can give me some helpful advice to get this Merc running so that I can get on the water to relieve some stress.
Thanks.
What I did:
Thanks.
