Just got back from looking at the boat again. Well the guy selling it to me gave me bad info on having to pump the primer bulb to keep it running.
I would use caution re; who you accept information from.
The mechanic started it up and it runs if you keep throttling it. He told me the carb needs rebuilt.
Make dang sure that the person who does the carburetor is familiar with the Solex Carbs!
If not, take it to someone who is!
Also, the ignition distributors on these OHC 4s are notorious for advancing flyweight operation issues.
Be sure to not only set BASE advance, but to also look closely at what the progressive and total advance numbers are doing.
Find your OEM ignition advance data (BASE, progressive and Total), and follow it to the T!
If the ignition system does NOT offer the correct progressive and total advance, performance will suffer!
I went over all the questions everyone has given me and it all seems to be in good shape. He is gonna rebuild it for 200.
And put new oil in the drive.
The stern drive should undergo a Pressure/Vacuum leak-down test.
The Pressure test must be performed with the drive oil drained.
The main drive gear, eccentric piston and prop shaft should all be rotated during the leak-down test!
The s/p drive uses 30W engine oil....... NOT heavy gear oil!
Thanks for the help I feel pretty good about this I will keep you updated and post pictures.
Thanks Ricardo
You are very welcome!
