Results 1 to 3 of 3
  1. #1
    Default want to set up throttle and shift cables on my yamaha 25esh
    I have a 2008 yamaha 25esh that I bought used and it has linkage on outside of the bottom cowling for throttle and shift cables. Where can I #1-find pictures of what it should look like as hook up, mounting brackets,cables and such and #2- where can I buy the bracket at least for the cables? I have some other cables like chrysler and maybe merc or johnson I could use and i think would hook up to existing yamaha levers. But I need the bracket to hold and brace the cables for movement.
  2. #2
    Default Re: want to set up throttle and shift cables on my yamaha 25esh
    any one? thoughts? ideas? suggestions? directions in where I might get info? Thank you in advance should any one be able to help?
  3. #3
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,961
    Ayuh,.... A good place to start would be the Yamaha Outboard forum, up closer to the top of the forum's main page,......
    Merc, 'n Johnnyrude use very different cable ends, so I gotta guess Yamaha does the same,.....
Similar Threads
  1. 90hp Force - Can you mix up the throttle and gear shift cables?
    By balmfort in forum Chrysler Force Outboard Forum
    Last Post: 07-04-2015, 07:30 AM
  2. help with tohatsu 90 throttle and shift cables
    By CreekCaptain in forum Nissan Tohatsu Outboard Forum
    Last Post: 01-27-2013, 02:10 PM
  3. How to connect Tohatsu MF-S6 cables to throttle & shift?
    By trihull in forum Nissan Tohatsu Outboard Forum
    Last Post: 04-25-2012, 06:25 AM
  4. Yamaha 2006-07 25ESH Throttle cable replacment
    By RonJB in forum Yamaha Outboard Forum
    Last Post: 08-08-2011, 02:09 PM
  5. Suzuki DF 115 throttle and shift cables
    By jskinner in forum Suzuki Outboard Archive
    Last Post: 08-29-2007, 11:30 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
