MercuryMariner
MercuryMariner
MercuryMariner
MercurySierraCDI
Results 1 to 8 of 8
  1. #1
    Default 1986 45 hp Mariner Motor oil Injection
    []I have a 1986 45 hp Mariner motor with autoblend oil injection. There is a hose going to gas tank and a hose going to motor. It appears to have a place for another hose (see picture). Am I missing a hose? Not sure what make the oil injection work? Do I need power to it. Any advice will help. Thanks
  2. #2
    Join Date
    Sep 2010
    Posts
    18,004
    Default Re: 1986 45 hp Mariner Motor oil Injection
    Take that " autoblend " unit to the nearest fence and toss it over and as far away as you can !!-----Just not a good / reliable unit.
  3. #3
    Quote Originally Posted by racerone View Post
    Bypass oil injection and mix fuel?
  4. #4
    Join Date
    Sep 2010
    Posts
    18,004
    ???----Throw that thing away !-----Mix 50:1 in the fuel tank.-----Use just one fuel hose.---Plug hose into the tank.-----Plug other hose end into the motor.-----Go fishing.
  5. #5
    So do I have to do anything to the engine to bypass the oil injection or just disconnect the fuel hose from autoblend injection tank and go directly from gas tank to engine?
  6. #6
    Join Date
    Sep 2010
    Posts
    18,004
    Was this a seperate " autoblend " tank somewhere in the boat , yes or no ?-------Do you see any oil injection components on the motor , yes or no ?-----Serial # of your motor ?-----Picture of the oil tank ?----I believe that post # 4 is vere clear !
  7. #7
    It is a separate tank. I am just wondering about what to do with the hose that goes into the motor from the autoblend tank. I will try and get some pictures. Mariner 45 HP serial number 0B146753. Thanks for your time.
  8. #8
    Join Date
    Sep 2010
    Posts
    18,004
    Is that a hose or wiring for an alarm ?
Similar Threads
  1. 1986 Yamaha PRO V 150 Oil Injection
    By [email protected] in forum Yamaha Outboard Forum
    Last Post: 10-08-2018, 11:06 AM
  2. 90 Mariner oil injection
    By Wasserhund in forum Miscellaneous marine engine topics
    Last Post: 10-14-2016, 04:32 PM
  3. 1986 suzuki oil injection
    By Pat Hagan in forum Suzuki Outboard Archive
    Last Post: 02-17-2008, 07:55 PM
  4. 1986 135hp Merc Oil Injection
    By saw in forum Mercury Mariner Outboard Archive
    Last Post: 11-24-2007, 10:24 PM
  5. 1986 45 Mariner noise in motor and then shut down
    By steve447 in forum Mercury Mariner Outboard Archive
    Last Post: 08-23-2007, 08:13 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
