Good Evening,
I have a 1978 Glasply with a Mercruiser 165. The boat will start up and idle just fine. But sense buying this boat last year, I have had the same problem of this boat stalling out and dying anywhere from 25 to 125 minutes at cruising RPM. When it begins to die, the boat will sputter in RPMs (high to low) and then die. The boat will not start up right afterwards however if you give it a few minutes it will start back up and idle. If you try to bump the RPMs up the boat will sputter again and die. I just installed a perTronic ignition system, spark plugs are new. The cap, rotor, and spark plug wires are newish. I just replace the thermostat. Last fall I took the cover off the fuel tank, completely drain the tank, installed two new filters and have only ran non eth gas. During operation the boat stays in the middle of the green arc, once dies obviously rises to upper green ark lower yellow ark. (my temperature gauge is just in colors no numbers). Coil is warm to the touch definitely not hot by any means when the boat dies. Out drive was just serviced and impeller changed. I'm at a loss for what else to replace to fix this issue. I live on a lake were an inconsistent boat could get you into a lot of trouble. Serious wind and waves, extremely limited docking and lots of rocky cliffs. I've done some reading on the forms here about other similar issues, some have suggested putting a relay in the coil wire to ensure it's getting maximum volts. I replace the coil six months before installing this new ignition system? Maybe I need to install a new coil? I guess it's possible that one shorted out with the old point system? I would enjoy any advice to help fix this issue and get a reliable boat, if there is such a thing
Thanks!
Thanks!
