First, Thanks for any advice anyone provides. I have completely rebuild the engine, fresh bore and a complete rebuild package. I have replaced the Impeller, and thermostats, however the port head keeps overheating when everything is together. I have good water flow from the tattletail, but nothing coming out of the upper exhaust ports on the midsection. I have ran the engine both on the hose and barrel. If I remove the thermostat housing and let the engine run it does not overheat. The water flow from both heads appear uniform but the water coming from the port head feels slightly warmer to the touch than the starboard. If I plug the Port head water flow with my finger it overheats right away, but doing the same thing with the starboard it says cool. The rubber defectors were present and appeared to be ok during the rebuild. Could the head be bad??? I pulled the head cover to make ensure it was free and not blocked but it was very clean. Am I missing something??? This isn't my first outboard rebuild. I have done several that were successful but still relatively new to outboard rebuilds. Thanks Again for any help.
