Aaronfromnz
Greetings all the way from little old NZ
Have recently bought a new weapon, 7m aluminium boat with GM 6.2 and aq280T unit.
Am in the process of resealing the trim system, have done the lower piston seals, just need some advice on getting the top part of the system to bits, I undid the ring of Allen bolts tonight but couldn't slide the tower up past the steering hoop, very hard finding information on this leg
anyone done this before do I need to undo the lower falk from the system? Can't even find a parts break down to see how t goes together/comes apart
Just to confirm it is the rare power trim/tilt system with the piston that goes at the bottom of unit and the single hydraulically (not mechanical worm)operated ram on the top
cheers
aaron
cheers
aaron
