Get instant online access to repair manuals for your Chrysler / Force outboard. Online Manuals
ChryslerForce
Order printed Chrysler / Force service manuals — shipped to your door! Printed Manuals
ChryslerForce
Use engine diagrams to find & order parts for your Chrysler / Force engine. Engine Diagrams
ChryslerForce
Results 1 to 8 of 8
    Default Power tilt works intermittenly
    I have a general question about the power tilt on a 1994 Force 90 hp. motor, mounted on a 1993 Spectrum 18 foot boat.
    It seems that the power trim does not always work. The switch seems dead at times, and then it works at other times. This has caused major problems at the ramp when I could not raise the motor to pull out. One time I had to jack up the motor to relieve pressure to make the trim work. I don't know if it is the switch or the trim motor. I would appreciate any help you can offer. Thanks. One more question...Same boat, how do you remove the throttle handle assembly from the boat when it has no visible screws? I am at my wits end with this thing. Thanks again.
    May 2010
    Sebastian ,Fl
    2,668
    Default Re: Power tilt works intermittenly
    Top mount or side mount shifter?
    Top mount: The button you push in to shift for fast idle can be pried out and a screw can be accessed.
    PICS??? that would help a lot.
    Side mount: the button or on the bottom of the handle might be a set screw?
    Again PICS??
    The [email protected] not working?
    They used 2 different types of [email protected] for the early 90's Forces.
    Could be a bad connection?
    The trim button on the handle, dirty connection,corroded contacts.
    The relays for the system, again dirty connections,corroded contacts.
    Intermittent operation: bad relays or solenoids.
    Really need to know what [email protected] you have??
    Pics of the [email protected] pump/motor, pics of the motor (all sides)with the cover off.
    PLEASE,NO PERSONAL MESSAGES IF THE QUESTION CAN BE ASKED ON THE OPEN FORUM
    88 Bayliner with 2002 225 HP Mercury
    Buy American made Cars and Trucks!!!Towing insurance,get it.
    In Scenic Beautiful Sebastian by the sea Florida
    Thanks Jerryjerry05. You helped me out before and I appreciate it. The boat is currently under two feet of snow, so it is going to take a while to get pictures. The throttle control is a side mount with no visible screws. Never gave relays a thought. Just getting my ducks in a row before the thaw. You gave me some good direction to go in. I will (of course) let you know how I make out when I can get to the job. Appreciate the tips.
    May 2010
    Sebastian ,Fl
    2,668
    The side mount either has a set screw on the bottom or the button pry's out.
    SNOW oh NO!!
    Jun 2006
    Spotswood, NJ, USA
    4,400
    almost all trim systems use a T & T switch and relays/solenoids. power is supplied to the switch , the switch operates a relay/solenoid that operates the trim motor. Most if not all problems are caused by a bad ground
  6. #6
    May 2010
    Sebastian ,Fl
    2,668
    The statement "Most if not all problems are caused by a bad ground"
    Depending on the year?? Most [email protected] problems are bad connections, bad relays/solenoids.
    Then the electric motor can contribute to the mix.
    If you had said, the connection? I would agree.
    One guy on another site couldn't figure out why the [email protected] system did NOTHING???
    He replaced the brushes, replaced the pump.
    He finally figured out, after 2 weeks, that the wire to the motor(1986 Force) wasn't connected at the battery.
    He'd installed the battery and put the battery on the end of the wire.
    His boat was a 86 Bayliner with a very small battery compartment.
  7. #7
    Thanks guys for commenting on my post. It has really helped. I have direction now, which I did not have before. As soon as the snow clears, I will be attacking the problem. I will let you know how it comes out, but it may take a couple of weeks. Thanks again.
  8. #8
    May 2010
    Sebastian ,Fl
    2,668
    Were here.
  1. Replies: 14
    Last Post: 07-31-2016, 10:44 PM
  2. 1974 OMC 400 Stringer Tilt up works, Tilt down is the problem
    By bresecker in forum OMC Sterndrive and Inboard Forum
    Last Post: 07-29-2016, 09:29 PM
  3. Replies: 6
    Last Post: 09-13-2012, 07:33 AM
  4. Replies: 1
    Last Post: 09-14-2011, 05:57 PM
  5. Tilt mechanism how it works
    By el_pescador in forum Volvo Penta Gas Archive
    Last Post: 08-22-2008, 02:15 PM
