I have late 90s BF50 (with controls) that has been giving me mysterious alarms for at least 6months. The alarms sometimes come & then go on their own. Other times i do something that seems to cure it, but then it eventually comes back. Nothing about these alarms is consistent. Its mostly a solid beep when in gear (and above idle), but ive also had it happen alot at idle & a few times even in neutral. Also, occasionally ive had an intermittent beep beep beep, but usually its solid. Sometimes the alarm wont start til ive been up on plane running for a little bit, but lately its often been sounding almost as soon as i put the boat in gear from startup.
The first time this happened the momentary cure was to slow down off plane to 3000 rpm or less. Lately ive had to slow down all the way to a slow idle or sometimes neutral to make it stop temporarily. A few times it was opposite and would sound at trolling speed, but getting on plane would seem to make it stop. Also, im not certain about this, but the otherday it seemed i could make it stop if i adjusted the trim up slightly then all the way down.
Adjustments that have seemed to make it go away for a longer period of time was a new battery. And another time, just putting an external charge on the battery. Howerever right now the battery is only a month old & rests at 13.5. When the motor is running it jumps up to about 14.5.
I should also mention that the motor will usually eventually bog down if i keep running thru the buzzer. The time it takes to bog down is not at all consistent; sometimes quickly, but sometimes it doesnt bog.
I pointed a heat gun at the motor and cant see anywhere its getting hot. Also, i tend to doubt it is because this beep often starts when the motor has only been running for a minute. I've only owned the boat 2 years and the temp & pressure lights have never been operational.
Ok now heres the most confusing part. Today i disconnected (at the motor) the temp sensor wire, oil pressure wire, and the trim sensor. IT STILL BEEPED!?
The only way i can permanently stop the alarm is by disconecting either of the two wires going into alarm itself under the console.
I would take it to a mechanic, except i was told by one that this model is too old to be hooked up to the computer to identify the issue. So its gonna need to be figured out on the water thru trial and error.
ANYBODY WITH ADVICE THAT CAN HELP ME SOLVE THIS IS MY HERO!
