I bought a new tank and hose for my Tohatsu 6hp last year from Defender. It is suppose to be OEM. The hose is 3/8. The o-ring seems damaged. Fuel leaks out when pressurizing and air gets in while running. I am in the Bahamas now with difficult access to Tohatsu parts. Even Merc are in limited supply. If I find a Merc OEM connector or replacement from Sierra or others should the parts be interchangeable?
If the origianl tank had 5/16 hose should a 3/8 hose connector mate properly with the Tohatsu engine side connector? Just checking if this might be the source of the o-ring damage.
Engine side port diameter is approx 8mm
Barb to port center approx 15mm
Barb length 21mm
barb diameter 6mm
Thanks,
Harry
Barb length 21mm
barb diameter 6mm
Thanks,
Harry
