Can’t build pressure by priming. Gas leaks out prop. Even when I isolate the fuel lines to the carbs same problem. It seems that the pulse limiter may be the source. The check seems to work, checks with pressure from the threaded end. No resistance thru the hose end.
I welcome anyones thoughts
thanks
thanks
