Results 1 to 3 of 3
Thread: Advice needed
    Default Advice needed
    I have a ford mermaid 2711E model which I have taken out of my boat and I am wondering if a ford 2712E model will fit on the mountings for engine, also will a Borg Warner gearbox fit as I am planning to remove from the mermaid 2711E and fit the ford sabre 2712E thanks
    Default Re: Advice needed
    Colly, Yes the engine block is identical, but the bolt on supports may be different dimensions so just swap them. Also the trans to flywheel housing are identical, but on some engines a 200# flywheel was used. It also is interchangeable and i suggest using it as it cuts down on vibration.
    Charlie W
    Thanks for the reply Charlie peace of mind before I go and get one thanks again
  1. Advice needed???
    By Aquaman1977 in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 02-09-2019, 09:39 PM
  2. help advice needed
    By aussie boatie in forum Suzuki Outboard Forum
    Last Post: 03-01-2017, 03:28 AM
  3. advice needed
    By aussie boatie in forum Mercury Mariner Outboard Forum
    Last Post: 12-28-2016, 07:24 AM
  4. Prop advice needed !
    By donzarelli in forum Yamaha Outboard Forum
    Last Post: 08-06-2014, 08:55 PM
  5. AQ290 advice needed
    By dougferony in forum Volvo Penta Gas Archive
    Last Post: 05-06-2008, 04:21 PM
