Johnson Fan
Hello,
I would appreciate some guidance with this project.
I am in the process of replacing the water tube to extend the shaft on my 3hp Johnson (1963, JW-17).
I have removed the lower unit from the power head with no issues; there were six screws.
I am at the point where the tube is connected to the shaft housing and can not see how to disconnect it. I don't see any threaded components other than what appears to be a clean-out plug located at the outside edge of the housing. I can peak through this small hole and can see no components which hold the copper tube in place. I don't imagine it was manufactured where this tube is permanently fixed to the housing.
I am stumped here. If any of you are familiar with these old engines - please advise.
Thank you,
Johnson Fan
Thank you,
Johnson Fan
