2003 dt225 engine trouble codes
wildboatride
hello I have a2003 dt 225 with a trouble code that says that the problem is the atmosphere pressure switch is bad every were I check says that model does not have one any help would be great thanks
Your MAP sensor on your motor will give you 2 different codes 3-4 is the code for the surge tank pressure [ inlet manifold ] and 3-2 is the code if the MAP sensor detects a problem with Barometric pressure before start up. this apply s if you have 4 stroke put you model number up we will tell you.
On the DT 2003 model the map sensor is called a Atmospheric pressure sensor and the code for it is also 3-4
yes I know that but all the paper work that I can find has no indication of one on the motor all the Symantec that I have found do not show one maybe you know where I can find It because its been like five months of looking with no luck thanks
