wildboatride
hello I have a2003 dt 225 with a trouble code that says that the problem is the atmosphere pressure switch is bad every were I check says that model does not have one any help would be great thanks
That is another term for MAP sensor, manifold absolute pressure
Apologies, I am referring to DF225, some times the air temp sensor is combined with the map, not sure on the DT
On the DT 2003 model the map sensor is called a Atmospheric pressure sensor and the code for it is also 3-4
