Results 1 to 4 of 4
    Default Install O-RING or don't install O-RING
    On a ALPHA ONE out drive changing the water pump housing, the kit came with a O-RING that would go on top or the drive shaft just under the splines. I,m getting mixed advice on what to do, some say don't install in cause it will cause a leak when putting back the lower unit it crimps up. and others say without it water will rot the splines. So O-RING or NOT?
    Jun 2006
    Spotswood, NJ, USA
    4,379
    Default Re: Install O-RING or don't install O-RING
    If you have the groove, use the O ring . The grease on the splines will keep the water out somewhat
    Sep 2010
    Jersey Shore
    5,071
    Quote Originally Posted by Bt Doctur View Post
    2x on this....
    Check the seals in the upper.
    Chris
    Dockside Marine Services
    Jersey Shore.
    Mercruiser/Mercury Certified
    Let the insanity begin.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,597
    Ayuh,...... Xs 3,.....
  1. Replies: 12
    Last Post: 07-17-2017, 05:45 PM
  2. 84 115 evinrude piston ring install.. which way does the 1 ring go?
    By comet424 in forum Johnson Evinrude Outboard Forum
    Last Post: 05-12-2015, 10:27 AM
  3. O-ring
    By Mopacknan in forum Johnson Evinrude Outboard Forum
    Last Post: 03-24-2015, 07:23 PM
  4. Clamping Ring O ring repl
    By jon_allen in forum Volvo Penta Gas Archive
    Last Post: 07-18-2008, 04:50 PM
  5. O Ring
    By Frank MacKay in forum Mercruiser Sterndrive Archive
    Last Post: 06-27-2008, 04:23 PM
