1987 Detroit 6V71TA
pto49
Current engine is rated at 435 HP. What is the lowest rated HP injectors that can be installed with TA engine and still burn clean?
You probably ought to ask Detroit Diesel, even if you buy the injectors somewhere else. If economy is the issue, going slower will make the engine last longer besides saving fuel. I've been running DDs since 1961. With naturals, we used many different injectors over a wide range without problems. But with a turbo you can cause damage and DD would be in the best position to have experience with derating an engine.
